Hello @saxo_29,
I’ve read through the owner’s manual for the 450 from 2003 onward (i.e., the SAM model), and the button in question is described only as a way to lock the vehicle from the inside.
The instructions for opening the 450 from the inside are as follows:
Opening the vehicle from the inside:
- Unlock the doors by pulling the door handle (C).
When the driver’s door is open, a warning tone sounds:
- if the engine is running, a gear is engaged,
and neither the brake pedal
nor the accelerator pedal is pressed.
- if the lights are on and the
ignition is off.
There is also a picture of the door handle labeled (C).
If you interpret all these indications correctly, you might conclude that your button is operating within its specified parameters.
Cheers
