saxo_29
Smart For Two 450 Coupe...issue with central locking button behind hazard lights
Hi all. Hope you are well.
I'm facing a weird issue with my Smart Passion 450 ( 2006) 700cc.
The central locking from key fob works perfectly. When I drive off, the car autolocking activates as it should. So far so good....
The problem appears when I want to unlock the door from the inside so that a passenger can open from the outside after the autolock has activated.
I press the "lock/unlock button on the triangle control panel right behind the hazard lights ( see picture ) , but it does nothing.... whether stopped in neutral, whether just getting into the car... pressing that button does nothing. Has anyone faced something similar or can shed some light as to what to look into? I do suspect the button switch itself but cannot be sure.
Thanks
I've been driving the very same 450 for 21 years w/o even knowing that this grey-ish arc-like button can be used to UNlock the doors. I've just never been in a situation than would have demanded using it to emergency-lock me in. To be fair, autolocking has always been activated. Can you still unlock your car from the inside by opening the driver door just a bit? Or by bending over the passenger seat and opening the passenger door from the inside?
bearbeitet von josmarlangner
Thanks for your reply Josmarlanger.
The autolock works perfectly, locking and unlocking from the FOB Key also works perfectly. If I reach to the passenger side, I can open the door perfectly. Just the button doesn't work. In the other Smart my wife had before, pressing this button you could lock or unlock the doors from the the inside. If the autolock was activated, all you needed to do was press that button when stopped and then someone could open the door from the outside as normal.
This function does not work on our Smart so I'm trying to see if I can fix it.
vor einer Stunde schrieb saxo_29:
Hello Saxo,
I just tried this function at my Smart 450. I found, this button can just lock the doors. After locking the doors with this button, further actuations of the button have no further effect. It is just a lock-button without an unlocking function. I think with using the autolock it is the same. This button cannot unlock the doors, regardless of which function was used to lock the doors.
If you have another Smart with this button having an unlocking function too, the function may have changed by smart over the years. My Smart is a ZEE model from the year 2001. It seems, your Smart is a late SAM model from 2006. So I suppose all 450 models have this locking-only function. Which Smart model does your wife have?
Regards, Hajo
Hello @saxo_29,
I’ve read through the owner’s manual for the 450 from 2003 onward (i.e., the SAM model), and the button in question is described only as a way to lock the vehicle from the inside.
The instructions for opening the 450 from the inside are as follows:
Opening the vehicle from the inside:
- Unlock the doors by pulling the door handle (C).
When the driver’s door is open, a warning tone sounds:
- if the engine is running, a gear is engaged,
and neither the brake pedal
nor the accelerator pedal is pressed.
- if the lights are on and the
ignition is off.
There is also a picture of the door handle labeled (C).
If you interpret all these indications correctly, you might conclude that your button is operating within its specified parameters.
Cheers
May i ask: How can i enable the autolocking on my 2004 450 cdi cabrio sam smart?
Is it a function that can be enabled via stardiagnose?
vor 29 Minuten schrieb Broxin:
Normally the Drivelock Function can be enabled via the owner! 😉
RTFM! 😇
Hello Saxo, "Moin" to the Community !
First of all: Please pardon me and excuse my bad english.....lessons in school are soo many years ago.....
for your note:
vor 11 Stunden schrieb saxo_29:
Afaik is this "behavior" of your car "normal" for the german models (here are two 450er cdi in using-mode for many years..., Years of building 2005 and 2006).
It is desciptet in the german "owners manual" as you sayed....
In my opinion the funktion (named "drive-lock") is as shown to prevent "criminal subjekts/persons" to get into your car as long as you and/or your passenger are inside. You and your passenger should be save... (from attacks to your body or theft of things from inside the car....).
Opening the car from inside ist possibel as the other users described....
And...ofcurse... the drive-lock-funktion can be enabled as the user "ahnungslos" sayes...
All described in the "owners manual / Bedienungsanleitung" for the german models...
But think about:
You are living in Athen/greece......I know nothing about the greece law of vehicel aquipments...it may be different to other countries....and the "local laws" may be different to all other countries over the world....i must not understand the goverments laws.....
best regards from
hedwig
    • Hallo. Ich gebe wirklich mein bestes schnell und zeitnahe zu antworten. Aktuell werde ich ihn heute erstmal überführen und hoffen das wir in meiner Werkstatt des Vertrauens dann ankommen. Ich muss dazu sagen, wenn er läuft, läuft er. Man kann nie sagen wann es passiert. Fährt man bei Regen, Nässe kommt das Problem (lt Vorbesitzer). Ich habe andere Erfahrungen gemacht. Über Huckel, abbremsen, Gas geben zum weiterfahren - aus. Die Batterie war dann auch beim Vorbesitzer dann irgendwann tot sodass er ein ladekabel während der Fahrt anschloss. Irgendwann war es ihm zu doof - Halle und ein Jahr stand bis ich ihn rausgeholt habe. Neue Batterie. Die Lichtmaschine war glühend heiß und fest - neu. Die DZM habe ich jetzt im Auge. Er ging seitdem aber auch nicht wieder aus als ich fuhr. Wie gesagt es passiert nur wenn: von schnell auf langsam und von langsam wieder auf schnell. Er säuft aber nicht ab?!? Fehler waren keine drin als er mal ausgelesen wurde. Ich werde das kommende Woche ansprechen in der Werkstatt (der macht viel umsonst da wir Freunde sind) ich danke erstmal und bin für weitere Tipps sehr dankbar. Liebe Grüße MAKS
