aCKtrion
2.521 -
Alle erstellten Inhalte von aCKtrion
I'm not sure about the fitting of the 18" without problems... As you can see in the Threads that i've linked, you can have luck and your wheels will fit without problems, as you can see at the yellow cab, or at the silver smart with the commercial stickers in the other thread. But there is also the possibility that the wheels you've chosen will touch a part of the chassis/the panels (look at the black smart with the black/chrome rims), in that case you must install "federwegbegrenzer" (i think "bump stoppers" is the right word...), maybe you must cut off some plastic of the panels either, if you chose 18" all around it seems like you must check this direct on your car... ;-) As far as I know, are 8,5"x18" the maximum for 451 anyway - maybe you try 8"x18" (or 7,5"x18" if you choose Azev) to make sure that you get no impossible problems... ----------------- 42 passion bj 2000 | silber/baygrey | powered by rs | >>> spritmonitor [ Diese Nachricht wurde editiert von aCKtrion am 15.06.2008 um 17:07 Uhr ]
Quote: Am 15.06.2008 um 14:17 Uhr hat leopedro geschrieben: For example i saw some new smart with 18" inch wheels, normally it sholud be better, but i do not know if 18 on the smart will increase handling or not. I'm not sure about the handling with 18" all around but I'll tell you with the normal engine and 18" all around you're not be able to drive highspeed records :-D But with a servo steering it should be no big problem... But it look's very good and fills the wheel arch completely - a combination of 17" in the front and 18" on the rear is also very interesting ;-) Look here (18") or here (17"/18") ----------------- 42 passion bj 2000 | silber/baygrey | powered by rs | >>> spritmonitor [ Diese Nachricht wurde editiert von aCKtrion am 15.06.2008 um 14:49 Uhr ]
Wer gibt für sowas 400000Euro aus...
aCKtrion antwortete auf rolandrunner's Thema in small-Talk (off topic)
Quote: Am 15.06.2008 um 13:40 Uhr hat Kevin_Lomax geschrieben: schau mal was die ganzen auf kundenwunsch handgefertigten hot-rod's in amerika für unsummen erzielen. da sind 500k usw. keine seltenheit. Es gibt da Fahrzeuge, die wären mir auch 'ne halbe Mille wert... ;-) Allerdings ist dieser Pseudo-Mercedes-Oldi wirklich keine Schönheit - viel zu inkonsequent umgesetzt, die historische Optik... :roll: ----------------- 42 passion bj 2000 | silber/baygrey | powered by rs | >>> spritmonitor -
Wollen wir mal hoffen, dass Püppi schnell wieder Fit wird ;-) Und dann muss sie noch ein wenig wachsen! Oh man, Katzen sind sooo nützlich... *schwelg* :-D PS: die Radkappe, die verhindert, dass die Katze bei hohen Geschwindigkeiten aus der Felge rutscht musste ich für das Bild natürlich abnehmen, sonst sieht man ja nüscht - nach der Fahrt sollte man die Katze einmal durchkämmen, je nach Zustand der Felge sammelt sich reichlich Schmutz im Fell :-D ----------------- 42 passion bj 2000 | silber/baygrey | powered by rs | >>> spritmonitor [ Diese Nachricht wurde editiert von aCKtrion am 14.06.2008 um 22:03 Uhr ]
Eigentlich dürfte sich da nicht viel tun, da der Diesel das was beim Benziner aufgefangen wird, mitverbrennt - der nimmt das nicht so Ernst... Was ist denn das für ein Abscheider? Der vom Udo? ----------------- 42 passion bj 2000 | silber/baygrey | powered by rs | >>> spritmonitor
Hast recht - die Alu Dark ist nur die zweit-schwärzeste, hab das Prospket nochmal rausgesucht, die Alu Dark ist zu 5% Lichtdurchlässig, die Black Mirror zu 2,7%... ;-) Aber ist trotzdem übel wenn man von Innen durchguckt, gelle? ----------------- 42 passion bj 2000 | silber/baygrey | powered by rs | >>> spritmonitor
Hi Roby! I have an old smart, so i can't really tell you about wheel sizes and comfort - but look at this: Quote: Am 01.05.2008 um 21:41 Uhr hat möma geschrieben: - Felgen sind ATS Aquila 7x17 ET 50 - Reifen sind Hankook Ventus S1 Evo 195/40/17 rundum - 3/5 Loch - Adapterscheiben : vorne 20mm / hinten mom. 28 mm Der 451 verträgt optisch auf der Vorderachse 17" einfach besser - zumindest mit der H&R Tieferlegung, die nur 1cm beträgt und dadurch noch "Raum lässt". 215/35 für hinten hatte ich auch zuerst im Kopf, aber der Reifenhändler hat mir abgeraten. Jetzt bin ich echt froh darüber, da ich einen gaaaaaanz deutlichen Komfortgewinn verbuchen kann (hatte 215/35/17 auf den alten Felgen). Auch kann ich nicht bestätigen, was mir ein Tuner bei den SmartTimes in Zell am See gesagt hat, dass 17 Zoll vorne beim 451 recht stuckig und hart zu fahren seien. Auch hier habe ich gegenüber den alten 16" deutlich an Komfort gewonnen. Ein weiterer positiver Nebeneffekt ist, dass durch den anderen Abrollumfang mein Smart um ganze 8-9 km/h schneller geworden ist - natürlich GPS-gemessen! War vorher durch die 195/40/16 bei 141/142 km/h Schluss, so sind es jetzt 149/150 km/h, bis der Begrenzer einsetzt - das entspricht am Tacho rund 155/156 km/h. With 17" on the front and on the rear (with 195/40/17) the comfort ist better than with 16" on the front an he's faster either :-D Here it goes PS: IMHO you should take 17" defintely - any smaller wheels will look very tiny in the wheel arch... ;-) ----------------- 42 passion bj 2000 | silber/baygrey | powered by rs | >>> spritmonitor [ Diese Nachricht wurde editiert von aCKtrion am 14.06.2008 um 16:42 Uhr ]
Mal eine grobe Auswahl ;-) Zeigt her eure kleinen smarties Zeigt mir eure aufgemotzten Oldliner Der "Meine Kugel hat was Neues...- Thread" Der "Mein Würfel hat was neues...-Thread" =) ----------------- 42 passion bj 2000 | silber/baygrey | powered by rs | >>> spritmonitor [ Diese Nachricht wurde editiert von aCKtrion am 14.06.2008 um 13:54 Uhr ]
Also seien wir mal ehrlich... ;-) 1.) Genau wie $ sagt, wie viele fahren Nachts mit Sonnenbrille? (also ich nicht, aber wie viele? Hmm?) Das ist auch nicht verboten, höchtens rechtlich ein wenig "hinderlich", falls man doch mal wen umnagelt... 8-) "It's never to dark, to be cool" :lol: 2.) Was hab ich mich bei meiner Heckscheibe erschrocken :roll: Das ist die schwärzeste Folie die es gibt, die sah im Prospekt soooooo furchtbar schwarz aus und wenn ich bedenke wie viel Licht da noch durchkommt - das ist ja der Clou, von aussen Schwarz, von Innen sehr durchlässig ;-) ----------------- 42 passion bj 2000 | silber/baygrey | powered by rs | >>> spritmonitor [ Diese Nachricht wurde editiert von aCKtrion am 14.06.2008 um 12:39 Uhr ]
@ Cadi Na hör mal :o - Pantera! Ich höre öfters, dass man mir meinen Musikgeschmack nicht ansieht, also denk dir nix dabei :-D (auch wenn er sich net auf Metal beschränkt) ----------------- 42 passion bj 2000 | silber/baygrey | powered by rs | >>> spritmonitor
Quote: Am 13.06.2008 um 20:57 Uhr hat smarty0 geschrieben: Wie wärs mit Panthera? Oh ja - Pantera! Klein, Süß, Schnuffig und einfach zum liebhaben - passt gut zu der Katze! :lol: Ich muss gestehen Schnupfi ist geil 8-) Aber Püppi is auch in Ordnung :) @ Sauerman :lol: ----------------- 42 passion bj 2000 | silber/baygrey | powered by rs | >>> spritmonitor [ Diese Nachricht wurde editiert von aCKtrion am 13.06.2008 um 21:04 Uhr ]
@ Kev Du Sack! Das Bild habe ich gesucht - du warst schneller... 8-) Hab mich so totgelacht, als ich es im Ami-Forum gefunden hab... :lol: ----------------- 42 passion bj 2000 | silber/baygrey | powered by rs | >>> spritmonitor
Ich würd ja gerne "Hubraum statt Spoiler" rufen, aber... :roll: ...smart halt 8-) Chaoti hat Recht, jedes mal dieser geschraubte Mist, ist doch ätzend - und diese blöden stummel Spoiler an der Front... Warum macht man nicht direkt einen schönen Spoiler draus? Und die Pseudo-Lüftungsschlitze hauen mich auch nicht vom Hocker - aus 20m Entfernung macht der Wagen was her, im Detail... :roll: Einzig das Blumenmuster hat was :) EDIT: Quote: Am 13.06.2008 um 00:22 Uhr hat schaefca geschrieben: Für Echtholzfußmatten werden nochmals 1 250 Euro fällig. :-D - lol... ----------------- 42 passion bj 2000 | silber/baygrey | powered by rs | >>> spritmonitor [ Diese Nachricht wurde editiert von aCKtrion am 13.06.2008 um 16:47 Uhr ]
Heute: smart Grand Slam Berlin & Beach Party
aCKtrion antwortete auf schaefca's Thema in Presse-Spiegel
Quote: Am 13.06.2008 um 15:14 Uhr hat Salzfisch geschrieben: Also seit heute Vormittag regnet es in Berlin - zum ersten mal seit knapp vier Wochen! Die armen Mädels in ihrem Crossblade... :roll: Tu ihnen doch einen Gefallen (und dir gleich mit) und bring ihn bei dem schlechten Wetter was zum überziehen vorbei - so weisse T-Shirts zum Beispiel... :-D ----------------- 42 passion bj 2000 | silber/baygrey | powered by rs | >>> spritmonitor -
*hochhol* Hey - seht mal, Tridion anbohren geht doch! (Auch wenn es merkwürdig aussieht...) ----------------- 42 passion bj 2000 | silber/baygrey | powered by rs | >>> spritmonitor
Quote: Am 12.06.2008 um 14:42 Uhr hat SirDaniel geschrieben: RUDEL GUCKEN BEI MADMIKE!! Trottel - es heisst "Gruppen-Glotzen" :-D @ Mike hast Recht - BuLi stinkt, nur Länderspiele und EM/WM sind lustig :) ----------------- 42 passion bj 2000 | silber/baygrey | powered by rs | >>> spritmonitor
@ Bobby Ich geb dir Recht - auch wenn der Umgangston hier manchmal auch ziemlich rau ist, ich lese regelmäßig im Ami-Forum und da gibt's genau die gleichen Klugscheisser, die dir direkt entgegenbrüllen "Na, des mog I net und des mog I auch net", "der ist aber viel günstiger", "das sieht aber scheisse aus"... :roll: Wundere mich immer noch warum hier manchmal auf das Ami Forum verwiesen wird, wenn wieder ein Thread ausartet, weil so viel besser sind die nicht - die haben bloß die aktuellere Software *duckundwech* :-D @ CDIler Ami-Forum ----------------- 42 passion bj 2000 | silber/baygrey | powered by rs | >>> spritmonitor [ Diese Nachricht wurde editiert von aCKtrion am 12.06.2008 um 16:38 Uhr ]
Quote: Am 12.06.2008 um 16:25 Uhr hat Kevin_Lomax geschrieben: fahren kann er ja.. Jooooaaa - ein bissel... :-D Tim Schrick ist einer der besten - "10.0"! ;-) Könnte wirklich sein und wär ziemlich cool, wenn's Wahr wäre... EDIT: Bin mal ein bissel rumgesurft und hab auf youtube das hier gefunden: Quote: Tim Schrick..there;s pics of him wearing the Stig Suit recording a new episode od top gear and with 3 Bugatty Veyrons and one CCX to play. Der Kommentar ist bereits zwei Wochen alt! ----------------- 42 passion bj 2000 | silber/baygrey | powered by rs | >>> spritmonitor [ Diese Nachricht wurde editiert von aCKtrion am 12.06.2008 um 17:52 Uhr ]
@ Signatur-Bruder "Schlaaaaaaaaand!" :-D ----------------- 42 passion bj 2000 | silber/baygrey | powered by rs | >>> spritmonitor
War sie nun schwarz, oder wie? Dann Snowball :) ----------------- 42 passion bj 2000 | silber/baygrey | powered by rs | >>> spritmonitor [ Diese Nachricht wurde editiert von aCKtrion am 11.06.2008 um 16:51 Uhr ]
Eindeutig Zweideutig: smart 42 oder MB CL 600?
aCKtrion erstellte ein Thema in Allgemeines Diskussionsforum
...oder auch: Was der smart mit einem Luxuscoupé gemein hat ;-) Als regelmäßiger Leser des Mercedes Magazins bin ich heute in der aktuellen Ausgabe (02/2008 ) über einen Artikel gestolpert, wo ich irgendwie grinsen musste 8-) In der aktuellen Ausgabe befindet sich ein Artikel über den CL 600, sprachlich wie auch rethorisch sehr gut gemacht (wie immer), aber irgendwie bin ich mir nicht sicher, ob sich der Text wirklich auf den CL bezieht - auch wenn auf den Bildern eindeutig ein CL zu erkennen ist, ich habe ein anderes Auto im Verdacht :-D Das geht schon mit der Beschreibung des Artikels ("Wie auf Wolken") los: Quote: Das Luxuscoupé ist Sinnbild für die aristokratischen Wurzeln der Marke, für Hightech und zeitlose Schönheit. Später folgen Sätze wie Quote: Mit faszinierender Leichtigkeit lässt sich der Mercedes-Benz durch enges Gässchenwerk steuern [...] Quote: [...] ein Manifest der Modellierkunst, der Linie, der Gediegenheit, für diese Universalsprache einer Karosserie zwischen Wille und Ausdruck, zwischen Gravität und Formenfluss. Geht es um Charaktersprache, um ästhetisches Mitteilungsvermögen, so finden sich die gebunden Kräfte in der Coupékarosserie am schönsten arrangiert. Das Coupé ist eine Luftgestalt mit satter Erdung. Hier wird es jetzt offensichtlich :lol: Quote: Völlig eigenständig aber präsentiert sich die Welt des Innenraums. [...] Und mittendrin im Fluss der Harmonien: die Uhr. Klein, klar, ein Statement zur Zeit. Herausgenommen aus dem Spiel der Eleganz, hat sie ihren unverrückbaren Platz gefunden, steht ausserhalb allen stilistischen und funktionalen Regelspiels. Denn sie verkörpert nicht mehr und nicht weniger als die genaue, für alle gültige Uhrzeit. Mehr kann man nicht verlangen. Wenn in einer Armaturentafel - und das passier selten genug - die Uhr freigestellt ist, weiß man: Hier sind Freunde der Vernunft am Walten, hier darf ein Gedanke vor dem anderen stehen, hier konnte sich ein klarer Geist durchsetzen gegen Bedenkenträger und digitalen Kleingeist. das mag jetzt ein wenig übertrieben klingen, ist aber zweifelsohne so: Analoge Uhren in Automobilen zeugen von einer höheren Gesinnung. Und mit ein wenig Kenntnis der Sachlage werden auch diese Zeilen wieder zur Hommage an ein ganz anderes Auto ( :-D ): Quote: Diese Imposante Motorkraft, diese Wucht der Beschleunigung ist jederzeit aktivierbar. Aber man tut es nicht. Man gefällt sich in der Reserve, im galanten Unterlaufen des Möglichen. Man imponiert mit Geschmeidigkeit und Ruhe. Also ich finde, die Sache ist glasklar :-D ----------------- 42 passion bj 2000 | silber/baygrey | powered by rs | >>> spritmonitor [ Diese Nachricht wurde editiert von aCKtrion am 10.06.2008 um 18:09 Uhr ] -
Da der Auspuff den großen Flansch hat, passt er nur, wenn du einen dazu passenden Turbo hast - ansonsten musste nur die Heckpanelhalterung leicht anpassen... ----------------- 42 passion bj 2000 | silber/baygrey | powered by rs | >>> spritmonitor
Ich find's auch geil - kommt am besten wenn man das ganze Set verbaut, Front, heck & Schweller, so wie hier ;-) Sehr schön! @ azurrr Mithilfe des Gutachtens das Michalak hat machen lassen? ;-) ----------------- 42 passion bj 2000 | silber/baygrey | powered by rs | >>> spritmonitor
Na das sieht doch mal vorbildlich aus 8-) Im Forum gibt's einige Threads zu dem Thema, so wie hier, oder hier, die können wir aus aktuellem Anlass eigentlich mal wieder hochholen :-D PS: @ MadMike, Salzfisch & bad jovish, geht doch mal mit gutem Beispiel voran :lol: ----------------- 42 passion bj 2000 | silber/baygrey | powered by rs | >>> spritmonitor
Die Anlage die am meisten Leistung bringt, oder vielmehr am wenigsten Leistung frisst, ist der Roady Pott vom 60KW Modell ;-) ----------------- 42 passion bj 2000 | silber/baygrey | powered by rs | >>> spritmonitor
