mottofreee
Probleme mit der Servobremse
This morning I left the Smart perfectly functional and this evening, after driving 100m, the brake pedal became stiff, I was left without power brake.
The car brakes but the pedal is very difficult to operate. I also felt a bit of ABS when I braked hard. For now I have concluded that the servo part is not working - tomorrow at the light I will check the vacuum pump and the vacuum pipe. I will also put MB Star on and see what it says.
Smart 450 CDI/2005
Sounds like a broken break booster. To check the device, press the brake pedal when the engine isnt running, keep the pressure and start the engine. If the break booster is functional, the pedal will yield a little. If not its likely that there is an issue with the booster unit.
vor 5 Stunden schrieb mottofreee:
this is the correct way, in most cases of missing booster support you will find the cause here. a defect at the booster itself is rare. but may also happen after these years.
Alles wird gut!
Howup , das war das erste, was ich versucht habe, wenn es geknackt hat.
Es knackt überhaupt nicht.
dieselboy , wenn ich die MB Star Diagnose durchführe, werde ich die Servomembran überprüfen.
MB Star a spus că totul este în regulă.
Am găsit ambreiajul pompei de vid rupt.
Problema rezolvata, lipsa vidului.
Acum voi înlocui piesa și lichidul de frână.
974330479_WhatsAppImage2022-11-12at17_32_31.thumb.jpeg.b15a747c85e57870ac41ab8348dc7c05.jpeg
1323681853_WhatsAppImage2022-11-12at08_15_50.thumb.jpeg.35c0054bd3f0b542fa0860b74ea37c4e.jpeg
bearbeitet von mottofreee
vor 23 Stunden schrieb mottofreee:
Was?
Warum lässt Du das eigentlich nachträglich noch mal durch einen Übersetzer laufen, damit es keiner mehr versteht?
Das war gestern noch auf deutsch da gestanden, dessen bin ich mir ganz sicher!
Deshalb konnte ich es gestern im Gegensatz zu heute lesen und verstehen!
Am 12.11.2022 um 16:42 schrieb mottofreee:
Problema rezolvata
Steht doch alles da! Ventil Schlauch abgebrochen, Problem gelöst!😁
Mein Rumänisch hinkt zwar ziemlich aber lesen geht gerade so.
Das ist schon klar, aber gestern war das alles komplett in Deutsch da gestanden! 🤔
Entschuldigung. Ich musste die verbleibende Sprache überprüfen, in Zukunft werde ich mehr darauf achten, was übrig bleibt.
Jetzt habe ich meine Nachricht noch einmal gelesen, sie ist mit diakritischen Zeichen geschrieben und ich schreibe nicht mit diakritischen Zeichen, also wurde meine Nachricht von jemandem oder etwas bearbeitet.
Meine Botschaft lautet:
MB Star sagte, es sei alles in Ordnung.
Ich habe festgestellt, dass die Vakuumpumpenkupplung defekt ist.
Problem gelöst, Mangel an Vakuum.
Ich werde jetzt das Teil und die Bremsflüssigkeit ersetzen.
Die meisten Rumänen, die Ihnen Ärger machen, sind eigentlich Zigeuner aus Rumänien. Und hier, in ihrem Heimatland, machen sie diese Probleme.
Also korrekt heißt das kaputte Teil Rückschlagventil, und die Frage ist, wer das abgebrochen hat, denn von alleine passiert das nicht. Und klar kann die StarDiagnose das nicht erkennen, da der alte Smart noch keinen Vakuumsensor hatte.
Die Bremsflüssigkeit hat mit dem Bauteil so viel zu schaffen wie das Motoröl oder das Scheibenwischwasser.
Ich lese aber raus, daran sind rumänische Zigeuner schuld, die auch in deutsch verfaßte Beiträge in diakritische Zeichen übersetzen. Solche Schufte aber auch.
Zu guter Letzt eine philosophische Fragestellung, die uns in der Bremsentechnik hier schon lange beschäftigt: Kann es einen Mangel an Vakuum überhaupt geben? Oder wäre das dann automatisch ein Zuviel an solchem?
Damit eine gute Nacht an alle.
bearbeitet von dieselbub
Alles wird gut!
vor 3 Stunden schrieb dieselbub:
Je mehr Löcher, desto mehr Käse, je mehr Löcher, desto weniger Käse, je mehr Käse, desto weniger Käse".😁
vor 8 Stunden schrieb Outliner:
Hast du da nicht den Ansatz falsch 🤔 ?
Lautet es nicht vielmehr:
  • Je mehr Käse -> desto mehr Löcher
  • Je mehr Löcher -> desto weniger Käse
  • Schlussfolgerung: Je mehr Käse -> desto weniger Käse 🤪
Hebt Euch das mal gut auf. Wenn wir mal eines Tages skynet lahmlegen müssen, dann mit sowas 😆
Alles wird gut!
...dafür gibt es Tic-Tac-Toe (nicht die Mädchen mit der Scheiße)!
Die Allegorie oben ist die Art, wie die "Grünen" hier in Hamburg für eine stadtweite Tempo 30 Regelung argumentieren. 🤮
dieselboy
1. Der Motor hat es kaputt gemacht . Dort ist er der Einzige, der fähig ist .
2. Die Idee ist, dass die Probleme, die Sie mit Zigeunern haben, auch in Rumänien liegen.
Ein Sprichwort sagt, dass der Wolf seine Haare ändert, aber nicht sein Temperament!
Dem automatischen Übersetzer fehlt es an Intelligenz und ich, ein Sprecher einer anderen Sprache, verstehe Ihr Wortspiel nicht.
Wegen Skynet mache ich mir wenig Sorgen: Da klingelt in Deutschland ein Faxgerät, spuckt ein Stück Papier aus welches abheftet wird. Nix mit Weltherrschaft!
schreibst du eigentlich gags für die heute show oder den böhmermann? das zeug dazu hättest du allemal 😜
Alles wird gut!
    • Guten Morgen,   es handelt sich um einen Cabrio und Benziner mit 220000km und Erstzulassung 25.8.2000. Die OBD-Buchse befindet sich im Sicherungskasten.   Mit kompletter Vorderachse meinst wirklich alles aus- und abbauen? Ich habe leider keinen eigenen Stellplatz, ich schraube immer auf dem Parkplatz von unserem Sportplatz bei mir vor der Haustür. Ich habe leider auch extrem neugierige Nachbarn und das gibt dann wieder Palaber, wenn da ein halbes Auto herumsteht. Deshalb seh ich immer zu, dass wenn ich anfange zu schrauben auch am selben Tag fertig werde oder zumindest es am Ende des Tage nicht wie eine Werkstatt im freien aussieht und das Auto halbwegs zusammengebaut ist. Trotzdem würde mich interessieren was ich alles tauschen müsste damit ich auf der Vorderachse erstmal Ruhe habe. Klingt als ob es mit Querlenkern, Traggelenken und Koppelstangen nicht getan wäre. Wie die Rostbehandlung zu machen wäre würde mich ebenfalls interessieren.   Zu dem Ölproblem ist es so, dass links, also das Getriebe feucht ist. Rechts ist es nicht so arg wie links und es scheint auch nichts zu tropfen. Ich schau drunter auf dem Boden immer nach bevor ich losfahre. Ich muss aber sagen, dass er am Anfang als ich ihn bekam getropft hat. Genau in der Mitte am tiefsten Punkt vom Getriebe. Er hatte auch nach dem Einsteigen und während der Fahrt arg nach Benzin gerochen, teilweise so schlimm, dass mir schwindlig wurde und ich Angst hatte im Auto zu rauchen. Der Vorbesitzer meinte er hätte kurz zuvor einen Ölwechsel gemacht und der Ölstand stand auch auf Max. Ich hatte dann als erstes das Teillastventil ausgetauscht, damit war dann komischerweise der Benzingeruch sofort weg. Das Tropfen hatte dann nach ein paar Wochen auch von selbst aufgehört und hat seitdem auch nicht mehr getropft. Jetzt ist es halt links nur arg feucht und ich tippe gerade spontan auf den linken Simmerring. Aber deshalb ja die Suche nach jemandem der mir das bestenfalls live bestätigen könnte.   Danke aber für deine Hilfe soweit
