Karl-Henrik
Smart-Hayabusa
I don´t want you to laugh at me, and i´m not drunk, i still want to be able to write at this Very nice Forum(U have helped me a lot) but...I have this strange idea (just an Idea/dream) to put a Hayabusa 1300 motor in my Smart...Now you probably think i am very very strange(i am Swedish)
Of course it's not the idea to get it thru the Tuv but....my dream could be possible with the right knowledge
Ok now u can tell me what u think (dont throw me out:) :o
My german is not that good in writing thou i understand whatyou write.
Gruesse von der alte Schwede
I believe, you'd need an other gearbox, which you'd have to adapt to the Suzuki engine and the Smart rear axle - because the Suzuki-transmission and clutch aren't strong enough (would simply blow because of the Smart's weight) and the electronic shifting of the smart transmission won't work.
...and you need a clutch, which allows you get your Smart going with about 5.000 or 6.000 rpm, because below the Suzuki engine doesn't produce enough torque and the engine would stall.
Well, I think: too many problems.
All the best,
Mark
Alter Schwede !! :roll: :-D :lol: 8-) :o ;-)
Tschö mit Ö diesahnebanane00008049.gif####Geschwindigkeit bringt Sicherheit####
Sheriff...
Take a look at www.radicalmotorsport.com.
they are using the bike gearbox thou they have the problem with not having a reverse gear.
Also that car is about 200 k lighter then the smart.
People race these cars in sweden and i talked to them last summer, they said that there was no problems.And the inventor was keen on helping me.
Hayabusa @ Smart sounds good but some years ago some friends of mine mounted a 600ccm Suzuki Motorbike Motor @ 90 HP on a CART (you know the little indoor-ones, not our smart ;-) ). The problem was not how to get the motor attached to the chassis, the shifting was easy, the sound was great but.... finally we died @ getting brakes for the vehicle :) The single disc brake from the rear axe blew within a few seconds of full braking and noone thought of installing disc brakes at the front tyres (as they do nowadays!).
So.... try your best with the hayabusa Motor, but don't forget to check the brakes :lol: :lol:
Yes the brakes are very important, true...
The whole idea is just thoughts.
The Smart would not be used everyday,and my mind says that it would be supercool to have a original Smart(on the outside)and just see peoples faces when u start it up :o ;-)
den gedanken könnte man -- ernsthaft -- weiterspinnen : welche motoren anderer autos würden in den smart passen (ich denke da an den 1.4 tdi -- damit würde die ölkugel zur dieselrakete) ?
smarte grüsse
:) jrr
smart cdi, was sonst ?
ps: ...wehr rechtschraibfeeler phindet, darf Sie behalthen ;-)
smarte grüsse
:-) jrr
cdi EZ 08/00
noe - also bitte keinen tdi, das - also - nein, bin sprachlos.
wie wäre es aber mit einem wankelmotor aus nem alten mazda rx-7? schön kompakt, geiler sound und leistung ohne ende - also DAS ding könnte man dann zum allgemeinem gaudium bei einem dragster bewerb präsentieren - traktion -> no problem, hinten die 215/35-17er unter den brabus kotflügeln, vorne 195er, kräftigere bremsscheiben vorne und sonst gaaaaaanz zivil und dezent lassen...
waere das leben nicht hart ohne einen smart?
keep on soft-tipping
martin
martin
Also das mit dem TDI - neeeeeeee, bloß nicht! Laute, klappernde Rappelkisten!
Wenn Diesel, dann Citroen/Peugeot oder Benz (z.B. A-Klasse).
Passt aber sowieso nicht!
Da bleiben wohl - wenn überhaupt - wirklich nur Motorradmotoren, und selbst dann müßte wohl der Kofferraumboden angehoben werden. Der Smart-Motor ist schon extrem klein! Meine Motorradmotoren waren bisher zumindest alle größer - vom Hubraum und von der Raumgröße!
:-D :-D :-D Oder 'nen Tuning-Anhänger, der den Motor trägt und den Smart schiebt! :-D :-D :-D
Mark
@sheriff:
ja, auf den anhänger einen scania v8 diesel, damit es schön sparsam wird, die kupplung vom lkw (oder besser ein hydraulikwandler), getriebe - wozu? zwei gegenläufige antriebswellen zum smart, damit´s nix umschmeisst bei dem drehmoment, im smart dann das diff - sollte bei ausgebautem motor/getriebe schon reinpassen, tankvergrösserung wird auch drin sein. vibrationsfreier lauf im smart wird auch sein, der hänger wird halt ein bisserl rappeln-egal. den scania motor auf biturbo umrüsten, leichtes tuning, 750ps und 2000nm bei 1200/min sollten dann schon drin sein. jetzt noch eine unauffällige gfk haube über das motörchen und auf den nächsten ampelsprint freuen.... :-D :lol: 8-)
martin
martin
Ah, der Martin versteht mich!
Guter Einwand mit den Antriebswellen - sonst rotiert der Smart vorne noch wie ein Grillhähnchen um die eigene Achse!
Aber scheiss auf die paar Literchen - nen schönen Ami-V8 Bigblock mit - sagen wir mal - ca. 7,5 Literchen - die kriegst du per Aufladung auch problemlos auf 750 PS und mehr, aber die klingen besser!! - und das ganze verchromt und unverkleidet, mit 8-Rohr Mad Max-Auspuff, der elegant unterhalb der Türen austritt. Ein paar kleine Versteifungen, damit sich beim Beschleunigen der Radstand nicht verkürzt, hinten etwas breitere Reifen (345er), damit die Kraft auch auf den Boden gelangt, und etwas Ballast auf die Vorderachse, damit Smarti keine Rolle rückwärts macht.
Mark
    • Moin Ahnungslos und andere,   kurze Frage zu diesen Reservesteckplätzen. Die Steckplätze R1 bis R4 (Klemme15/Zündungsplus): Ist davor noch eine Sicherung? Oder gibt es bis zur Batterie nur die Sicherung in dem Adapter? Hintergrund der Frage: Ich habe auch diese Ausfälle der Kraftstoffpumpe und möchte die Kraftstoffpumpe mit Zündungsplus ansteuern (Crashsensor hin oder her, es geht anscheinend nicht anders. Wen die ganze (längliche) Geschichte interessiert: hier die Historie:   Schon einige Monate nach dem Kauf des Smart vor 3 Jahren ging er während der Fahrt sporadisch aus oder lies sich nicht starten. Fehlercode P0251. Zündung aus und warten auf Reboot des SAM half immer und hilft auch heute noch. Zunächst habe ich mit WD40 operiert. War danach eine zeitlang seltener. Dann habe ich das SAM ausgebaut, an diversen STellen nachgelötet und am Stecker 11.3 das Kabel für die Kraftstoffpumpe direkt platienenseitig auf den Lötpunkt des STeckerpfostens gelötet. Die Ausfälle wurden deutlich seltener, aber anscheinend gibt es neben dem STecker noch ein weiteres Problem. Im nächsten Schritt habe ich auf das Kabel ZUSÄTZLICH über einen Schalter im Armaturenbrett Zündungsplus gelegt. Zumindest war Zündungsplus der Plan :-). Habe mit einem Relais direkt Strom von der Batterie geholt (natürlich über einen zusätzliche Sicherung in der Zuleitung). Die Steuerspannung für das Relais habe ich vom Zündungsplus des Zigarrettenanzünders über diesen Schalter geholt. Also dachte ich, das sei wie Zündungsplus. Nun liegt diese Spannung aber ZUSÄTZLICH an der Pumpe an. Warum ZUSÄTZLICH? Ich wollte den Schalter eigentlich standardmäßig ausgeschaltet lassen, so dass der Chrashsensor etc noch klappt und diesen Schalter nur im Notfall betätigen. Beim Ausprobieren meiner Schaltung musste ich aber feststellen, dass ich mir eine Art "Selbsthaltung" eingebaut habe. D.h. wenn der Schalter an ist während der Motor läuft und ich die Zündung abschalte, bleibt der Motor an und auch alle Verbraucher an Klemme 15. Offensichtlich entsteht über das angezogene, reguläre Kraftstoffpumpenrelais eine Verbindung zwischen Klemme15 und die Batterie. Hab's erstmal so gelassen, sollte ja nur ein Notfallinstrument sein. Dann war wochenlang Ruhe, keine Ausfälle. Vor zwei Wochen ging es wieder los. Motor aus im Dunkeln auf einer Landstraße, gruselig. Habe hoffnungsfroh den Not-Schalter betätigt, aber nur der Anlasser drehte, kein Anspringen. Offentsichtlich sperrt das SAM den Motor erstmal, wenn der Fehler P0251 erkannt wurde. Da hilft auch Not-Strom auf der Pumpe nicht. Erst nach dem SAM Reset gings weiter. Ich fahre jetzt stets mit dem eingeschalteten Schalter als Notlösung. Den Kleinen muss ich FAST immer durch Betätigen des Schalters abstellen. Aber nur FAST. Manchmal geht er auch trotz eingeschaltetem Schalter mit dem Zündschlüssel aus. Obwohl im Fehlerspeicher nichts abgelegt ist, gehe ich davon aus, dass dann der Fehler aufgetreten ist und das Kraftstoffpumpenrelais auf dem SAM während der Fahrt abgefallen ist. Ich vermute, dass der Fehler erst gesetzt wird, wenn der Karftstoffdruck fehlt. Und das geschieht durch die Notlösung nicht mehr. Mein Plan jetzt: Echtes Zündungsplus über den Schalter für die Bestromung der Pumpe verwenden. Das dürfte die nervige "Selbsthaltung" ausschalten. Alternativ könnte ich natürlich die Kraftstoffpumpe auch nur über das zusätzliche Relais mit Zündungsplus schalten. Dann wäre aber "normaler Betrieb" mit dem Crashsensor nicht mehr möglich. Außerdem weiß ich auch nicht, ob nicht noch irgendwelche Schaltungsteile/Strompfade zwischen Ausgang des originalen Pumpenrelais auf dem SAM und dem Stecker 11.3 Pin 10 auf Spannung angewiesen sind.
