creamstyler
things that really matter
A MAYONNAISE JAR AND 2 CUPS OF COFFEE
When things in your life seem almost too much too handle, when 24 hours in a day are not enough, remember the mayonnaise jar and the 2 cups of coffee.
A professor stood before his philosophy class and had some items in front of him. When the class began, wordlessly, he picked up a very large and empty mayonnaise jar and proceeded to fill it with golf balls. He then asked the students if the jar was full. They agreed that it was.
The professor then picked up a box of pebbles and poured them into the jar. He shook the jar lightly. The pebbles rolled into the open areas between the golf balls. He then asked the students again if the jar was full they agreed it was.
The professor next picked up a box of sand and poured it into the jar. Of course, the sand filled up everything else. He asked once more if the jar was full. The students responded with a unanimous "yes."
The professor then produced two cups of coffee from under the table and poured the entire contents into the jar, effectively filling the empty space between the sand. The students laughed.
"Now," said the professor, as the laughter subsided, "I want you to recognize that this jar represents your life. The golf balls are the important things- your God, family, your children, your health, your friends, and your favorite passions - things that if everything else was lost and only they remained your
life would still be full.
The pebbles are the other things that matter like your job, your house, and your car.
The sand is everything else - the small stuff.
If you put the sand into the jar first," he continued, "there is no room for the pebbles or the golf balls. The same goes for life. If you spend all your time and energy on the small stuff, you will never have room for the things that are important to you. Pay attention to the things that are critical to your happiness. Play with your children. Take time to get medical checkups. Take your partner out to dinner. Play another 18. There will always be time to clean the house and fix the disposal. Take care of the golf balls first - the things that really matter. Set your priorities. The rest is just sand."
One of the students raised her hand and inquired what the coffee represented.
The professor smiled. "I'm glad you asked . It just goes to show you that no matter how full your life may seem, there's always room for a couple of cups of coffee with a friend."
wählt EEE !
:cry: fööön... :)
Na Leifi, wann trinken wir einen Kaffee? :roll:
Dicken Drücker und bis bald,
Maike
In Farbe uuund buuunt
Worte die einen doch wirklich mal überlegen lassen!!! :roll:
...dat Gemurmel und der Paul!!!
db_image.php?image_id=837&user_id=324&width=160
*powered by RS-Parts*
Rhein-Ruhr-Smarts
262-401-376online.gif?icq=262401376&img=21
[ Diese Nachricht wurde editiert von MurmelXL am 08.05.2007 um 11:01 Uhr ]
*...Pünktlich, eine halbe Stunde zu spät!*
db_image.php?image_id=2065&user_id=324&width=468?no_cache=1256469680
Banner_Murmel_468x71.jpg" border="0
Die bessere Wahl in Hamburg
Hier geht es zu unserer Facebook Seite
Am 08.05.2007 um 09:29 Uhr hat HaseII geschrieben:
:cry: fööön... :)
Maike
redrueck :) gaaanz bald, vergesprochen.
wählt EEE !
ich find den text auch schön. ich möchte allerdings zu bedenken geben, dass es auch einen gedanken wert ist, dass viele leute dazu so nette moderne fabeln brauchen, um sich über solch essenzielle dinge gedanken zu machen (um es wahrscheinlich eine minute später wieder vergessen zu haben) …
beste grüße
xordinary
Danke Leif!
Ja, das ist wirklich ein gelungener Vergleich mit dem alltäglichen Leben!
Komm doch mal auf'n Cappu vorbei, wenn du im Süden der Republik bist ;-)
Gruss Reinhard
online.gif?icq=159300280&img=3
Scheint ne perfekte Werbestrategie des Kaffee-produzierenden-Gewerbes zu sein :-D
it works 8-)
Spass beiseite: mit diesem Bild vor Augen sollte man sein Leben organisieren :roll:
Leif kommst du zu uns?? *willauchleifisehen*
Unsere Furcht, zu weit zu gehen,
hindert uns oft daran, weit genug zu gehen.
Die neue Aktion der sagenumwobenen Typenaufkleber!!
Mit jeder Träne, greift die Seele nach der Freiheit.
Wenn aus den Tränen schließlich ein Lächeln entsteht,öffnet sich der Himmel.
    • Ich denke mal, der Funman meint den Drehwinkelsensor, der am Getriebe angeschraubt ist und synchron zur Schaltwalze gedreht wird. Auf dieser Seite wäre es die Nummer 2. Wie Du auf dem unten stehenden Bild erkennen kannst, handelt es sich dabei um ein großes Drehpotentiometer mit mehreren Bahnen, welches dann einen Analogwert zum Motor-/ und Getriebesteuergerät, das ja beim 450er Smart ein gemeinsames und am Luftfilterkasten montiert ist, dort wird der Analogwert digitalisiert, damit er vom Rechner da drin verarbeitet werden kann. Beim Anlernen des Getriebes werden ja alle Gänge durchgefahren und der jeweilige Wert wird dann hexadezimal im MEG abgespeichert. Im laufenden Betrieb wird dann permanent ein Vergleich zwischen den aktuellen und den abgespeicherten Werten vorgenommen.   Parallel dazu sind in den Motoren des Kupplungs- und auch des Schaltaktuators Inkrementaldrehgeber verbaut, die jeweils zwei Rechtecksignale an das MEG senden, aus denen dieses die Drehrichtung und die zurück gelegte Strecke dieser Motoren decodieren kann.   Es handelt sich hierbei durchaus um ein komplexes System, das ist alles andere als trivial. Und deshalb ist auch die Fehlersuche darin ohne Diagnosesysteme eher ein Stochern im Sumpf als ein zielgerichtetes und systematisches Vorgehen! 🥺 Vor allem wenn er auch noch wie in Deinem Fall nur sporadisch auftritt und nicht ständig vorliegt.   Diesen Drehwinkelsensor gibt es übrigens bei Smart nicht mehr als Ersatzteil zu kaufen, von daher ist ein Tausch auf Verdacht gar nicht möglich. 😢   .
