Udo_B
TÄST
nur 'n Test!
[Diese Nachricht wurde von Udo_B am 01. Mai 2001 editiert.]
:classic_smile: Luder und Udo danken RODI :classic_smile:
Staaak, Udo!
See ya on the Smart-Parade?
Frieda und Dieselinchen
@silver
wenn du ein bild einfügen willst, nicht die Seite angeben "http://members.tripod.de/Silversmart/id21.htm" sondern die entsprechende *.jpg datei. z.b "http://members.tripod.de/Silversmart/0b1266a0.jpg"
ciao
uwe
www.hermann-world.de
[Diese Nachricht wurde von Uwe_H am 13. Juni 2001 editiert.]
Nochn Täst!
Mein erstes gepostetes Bild von meinem kleinen! :classic_smile:
Drölfter Versuch!
[Diese Nachricht wurde von Bumbastico am 16. Juni 2001 editiert.]
Es Funzt, es funzt!! :classic_smile::classic_smile::classic_smile::classic_smile::classic_smile::classic_smile::classic_smile::classic_smile: :classic_smile: :classic_smile::classic_smile::classic_smile::classic_smile::classic_smile::classic_smile::classic_smile: :classic_smile: :classic_smile::classic_smile::classic_smile::classic_smile::classic_smile::classic_smile::classic_smile: :classic_smile: :classic_smile::classic_smile::classic_smile::classic_smile::classic_smile::classic_smile::classic_smile: :classic_smile: :classic_smile::classic_smile::classic_smile::classic_smile::classic_smile::classic_smile::classic_smile: :classic_smile: :classic_smile::classic_smile::classic_smile::classic_smile::classic_smile::classic_smile::classic_smile: :classic_smile: :classic_smile::classic_smile::classic_smile::classic_smile::classic_smile::classic_smile::classic_smile: :classic_smile: :classic_smile::classic_smile::classic_smile::classic_smile::classic_smile::classic_smile::classic_smile: :classic_smile: :classic_smile::classic_smile::classic_smile::classic_smile::classic_smile::classic_smile::classic_smile: :classic_smile: :classic_smile::classic_smile::classic_smile::classic_smile::classic_smile::classic_smile::classic_smile: :classic_smile: :classic_smile::classic_smile::classic_smile::classic_smile::classic_smile::classic_smile::classic_smile: :classic_smile: :classic_smile::classic_smile::classic_smile::classic_smile::classic_smile::classic_smile::classic_smile: :classic_smile: :classic_smile::classic_smile::classic_smile::classic_smile::classic_smile::classic_smile::classic_smile: :classic_smile: :classic_smile::classic_smile::classic_smile::classic_smile::classic_smile::classic_smile::classic_smile: :classic_smile: :classic_smile::classic_smile::classic_smile::classic_smile::classic_smile::classic_smile::classic_smile: :classic_smile: :classic_smile::classic_smile::classic_smile::classic_smile::classic_smile::classic_smile::classic_smile:
Dank Elmars Tips!
[Diese Nachricht wurde von Udo_B am 24. Juni 2001 editiert.]
nochn test
Austria is smarting!
grüsse,
sutch +
chucky, die Mörderkugel
[Diese Nachricht wurde von sutch am 24. Juni 2001 editiert.]
so, bin mal gespannt, obs jetzt klappt...
grüsse, sutch +
chucky die Mörderkugel
buhu, klappts diesmal endlich?
nein, klappt nicht! :classic_mellow:
kann mir jemand sagen, wieso das bild im Beitrag da is, aber in der Signatur nicht mehr?
das klappt ja normal mit den smilies auch?!
bitte helfen!!!
na toll!
jetzn hab ich den Beitrag editiert, und jetzn sieht mans! keine Ahnung, was da los is, hat jemand ne idee?
grüsse, sutch +
    • Ein Bild aus Vediamo habe ich auch, hänge ich dran. Der Unterschied liegt in der Zeile „SCN 6 … Bit 4“ vorher kein Haken, nachher ist ein Haken zu sehen weil das Bit gesetzt ist. Für die 60kW Variante musst du aus der 09 eine 11 machen. Damit wird dann das Bit 5 gesetzt.  Das ganze beruht auf dem Hexadezimalen System und dem Binärsystem. Eine Zahl im Hex System entspricht 4 Bit im Binärsystem. Die beiden Zahlen im Offset 06 sind also Binär gesehen 2 mal 4 Bit. In Summe dann 8 Bit oder auch 1 Byte. Man liest die Position von rechts nach links. 01 Hex = 0000 0001 Binär  09 Hex = 0000 1001 Binär hier ist das Bit 4 im 2. Block dann auf 1. 11 Hex = 0001 0001 Binär hier ist dann das Bit 5 auf 1. 41 Hex = 0100 0001 Binär hier wäre dann das Bit 7 auf 1 was dann 74kW wären. Ich hoffe das ist halbwegs verständlich.  In Tom‘s Tool sollte sich das dann auch entsprechend ändern und die Haken, bzw. X angezeigt werden.    Klima hat er nicht das stimmt bei mir. Tempomat war zu diesem Zeitpunkt nicht codiert.  Tom hat da viel Reverse Engineering betrieben, hat aber auch noch nicht alles gefunden und das ganze ist experimentell, kann also durchaus noch Fehler haben. Es sollte sich jeder bewusst sein das man hier sehr leicht sein Steuergerät unbrauchbar machen kann! Der Vorteil auf Hardware Ebene das man alle Softwareseitigen Sperren / Einschränkungen umgehen kann. Heißt aber auch es gibt doppeltes Netz oder Boden. Es wird nicht validiert was ihr dort macht bevor es geschrieben wird! Habt also IMMER mindestens 1 Backup zur Hand!   Ja das Auto läuft ohne Notlauf oder sonstigen Problemen.
