Caveman
Biete Smart Handschuhfach und Radioblene in blau
klaro..mach mir n angebot.... :-D
du hast gelesen das das handschuhfach leicht verkratzt ist?
    • Hello @saxo_29, I’ve read through the owner’s manual for the 450 from 2003 onward (i.e., the SAM model), and the button in question is described only as a way to lock the vehicle from the inside. The instructions for opening the 450 from the inside are as follows:   Opening the vehicle from the inside: - Unlock the doors by pulling the door handle (C). When the driver’s door is open, a warning tone sounds: - if the engine is running, a gear is engaged, and neither the brake pedal nor the accelerator pedal is pressed. - if the lights are on and the ignition is off.   There is also a picture of the door handle labeled (C).   If you interpret all these indications correctly, you might conclude that your button is operating within its specified parameters.   Cheers Marc
