Anonymous
English Smart Modifications
Where are you living ?
Smarts not common in the UK so you must be the talk of your street.
How much have you paid for your licence plate ? (As I remeber from my time in the UK the x-range is quite a while ago and nowadays you have some "information" about your area.)
Have a nice time.
Gee
hi! i've seen your mods at the S2SCREW! :-D
very nice!!! even the rear-view is something special. but the only "not-so-nice-thing" are the exhaust-holes. do you really want to use those lumma-fake-exhausts????? :o
The Devil's Advocate
...und sein "Kenny" IN-RW 97
Gründer und Webmaster der...
that was me
*winkewinke an MCC, lest schön mit*
Konzertsmart No.2
Die Anleitung für den Bodypaneltausch
Smart Organisaton Stuttgart
Member of the SOS
Hi Kevin,
I am NOT using the Lumma exhaust but a custom made centre exit system. I couldnt mesh the side holes as the standard exhaust I have on is in the way. A hole will be cut in the current mesh to allow the exhaust to go through the back.
The X number plate is standard for the Uk for cars sold 1 1/2 years ago, the new ones only started september last year.
aNdY
UK
Hi!
If you have an e-mail addy, please mail me, I have an important question.
    • Was du auch machen kannst, mehrfach für 2-3 Sekunden Zündung an und erst dann anlassen. Damit fördert die Benzinpumpe mehrfach vor, das tut sie aber nur für etwa 2 Sekunden, deswegen mehrfach Zündung an. Löst nicht den Fehler, schont aber eventuell deinen Anlasser und Batterie.
