puffopazzo
aux cable
Hello, I'm italian, so sorry for the lenguage... I bought an aux cable from ebay to connect my radio to an external input. When I put it on the back of the radio it doesn't work. Loking on other pictures I see there are about 4 cables that enter on the iso connector but I have3 cables. Can someone tell me if this may be the problem? May someone help me? Thank you
Hi to Italy ;-)
here you find a picture of the Grundig car radio rear panel. the pins that might interest you in that case ...
13- CD-bus
15- ground
18- input ground
19- input left channel
20- input right channel
If I´ve got it right you must connect pin 13 with pin 15. I think this simulates to the radio that the cd-changer is pluged in.
No guarantee that it works- if you´r not absolutely shure post some pictures bevor connecting it to your car!
Self soldered plugs may cause an short-circuit which can damage automobile electronics!
kind regards
Jens
..:Wer Smart säht wird Mercedes ernten:..
    • Erreicht der Smart die Betriebstemperatur (3 Eier 80°C) ?   Wenn ja, kann es sein, daß dein Vorbesitzer Kollege Kühlerdichtmittel Zeugs in den Kühlwasserkreislauf gekippt hat und der aktuell verbaute Heizungswämetauscher verstopft ist.   Funktioniert das Innenraumgebläse korrekt?
