Carl
2 l oel auf 2000 km??
Hello my german Smart friends!!!
One month ago i went back from Switzerland to Sweden, driving happily home with my Black Jack that had just been on checkup for 60 000 km(650fr).
Beeing very satisfied that they told me that the car was in good shape and very well kept.
Yesterday SCHOCK!!!!!!!!!!!!!!!!!!1
After have made 2500 km yesterday the OIL lamp came out!!!!!!
I of course stopped the car imediatly, checked the oil: Leer!!!
Ok, i know u should check the oil every 1000 km but the car had just been on SC and when we filled her up it went in 2 lL!!!!!!!
I´m really pissed now and tomorrow i will call Smart in Switzerland.
What do u guys think i should say, because this is far from normal don´t u agree??
You have helped me before
Vielen dank!
Sie können auf deutsch antwort geben.
Carl
(habe jetzt 62320 auf den tacho)
Carl
perhaps they´ve not filled up the oil correctly to max ??
viele grüsse
True!The thing is that it's not nice to pay a lot of money to SC and they don't fix or change the oil!?
Carl
have you excluded a technical defect yet?
i would fill up the engine again with oil following a short and carefull drive to see what happens.
1 liter of 1000 km is normal wear out, IMHO
Is one liter wear out on 1000 km normal?
Seems a little much
Carl
Hi !
Pls check for a leakage near the oil filter. You may have lost some oil. Max.consumption ist 1 L / 1000 km. MY cdi needs 1 - 1,5 L / 12500 km (between two services).
Greetz
Christian Unger
smart pure cdi
Mein Smart
Christian Unger
smart pure cdi
Mein Smart
Vielen Dank!!!Going to bring the Smart to SC in Stockholm for a check up.
Carl
Best regards to sweden!! :) :) :)
The smart brings european people together, what do we want more??? :-P :-P
I think too, there must have happen a mistake when changing the oil.
Leakage near the oilfilter (or so) seems plausible.
Much Luck with SC in Stockholm ;-)
Thomas
    • Moin liebe Gemeinde ! Ich brauche mal ein wenig Input. Als ich das Licht einschaltete, funktionierte das Standlicht und auf Stufe 2 nur das Fernlicht. Das Abblendlicht war auf keiner Schalterstellung einzuschalten. Ich hab den Schalter ausgebaut. Ok, drinnen alles Schwarz, die Adern blank. Also, einen (vorher getesteten) anderen Schalter eingebaut. Ergebnis nur Fernlicht, keine Umschaltung möglich. Noch einen anderen Schalter eingebaut mit dem gleichen Ergebnis. Sicherungen gecheckt, alles ok. Nun habe ich leider keinen Schaltplan und auch keinen Belegungsplan für die Relais. Kann mir jemand weiterhelfen ?
