czy
auspuff (exhaust system)
Hey,
I am Peter from belguim and I am an owner of a Smart Cdi 12/00.
I want to buy an axhaust system for my Cdi but I dont know what I have to buy.
A BRABUS is too expensive!!!!!!!
SW is cheaper but how is the quality, does it make much noise. I don't want to much noise, I just want more torque!
Can anyone help me????
You may reply in German!
Thank You
Peter
Hi Peter!
A good reason for improving my poor english...
I know about one exhaust for the cdi exept SW and Brabus, this one:
It costs about 816 €, is made of stainless steel, but I have never seen / heared it in real!
You can get it here: STC
The SW-exhaust is a modifies stock exhaust, there are two outlets weldet in the middle and the exhaust is polished well.
The original outlet is sealed!
The sound is not very decent ;-) but the sound intensivity can be influenced by modifying the outlet-size inside the tubes, probably SW constructs a more gentle version??!!
The Brabus is the most uncomplicated possibility getting "sound" and torque (not really!!) for your smart.
Expensive, questionable sound quality but nice looking, indeed.
All the other exhausts, CS-Tuning, TTP, etc. are not suitable for the cdi :(
After all, you won´t get real torque-improvement!
The cheapest way getting more sound is to modify an exhaust by your own, but this really isn´t suitable for you if you don´t want a sound-improvement ;-) because sound improves a lot :-D
My advice: Take SW, you will like the sound, optics and the price (404 € incl. steel cover) and because the basis is a stock-exhaust, the quality is all right.
Regards, Ingo
Von www.fahnenversand.de:
Beschreibung:
Regenbogenfahne
Material: Polyester
Größe: ca. 150x90cm (BxH)
Die Flagge ist an der kurzen Seite mit 2 Ösen versehen
und kann auch an einem Stock oder action-smiley-075.gifÄhnlichem action-smiley-081.gif befestigt werden.
Thank you Ingo for your reply!!!
The SW exhauwst costs 404 Euro but this is without the installation costs.
The factory of SW is in Wiesbaden and this is pretty far for my.
Is it possible to install the "auspuff" myself.
Regards Peter
Hi!
The exaust-installation is no problem at all, you easily can do it youself:
First you have to get the tools you need:
The Torx-bit for bopypanel removement (normaly includet in any bit-set), 13mm socket and a ratchet plus extension and link!!
To unscrew the screw at the gear unit / exhaust holder you can use a normal socket.
Removing the panel is no problem at all (pull abaft, not laterally!!).
The exhaust is screwed on the Turbo with two bolts/nuts and one screw on the gear unit.
It will take you 20 minutes...without ruffle or excitement ;-)
I suggest to write an email to SW, they will response immediatly, I suppose!
Tell them, you dont want it too loud... but I´m shure, you´ll like the full sound after all!!
Do you have any regulations like german TÜV in Belgium?
Regards, Ingo
Beschreibung:
Regenbogenfahne
Material: Polyester
Here´s a closer view:
Ingo
[ Diese Nachricht wurde editiert von trueblue am 15.12.2002 um 10:59 Uhr ]
Beschreibung:
Regenbogenfahne
Material: Polyester
Danke Ingo,
I have allready sent an email to SW.
I've I have a reply I will let you know
Greetings Peter
Ingo,
Do you also have an SW "auspuff"???
Ciao pé
No, I modified an exhaust by myself.
I inserted a tubing connecting the middle chamber directly with the original outlet.
Great sound at low costs!
Works with cdi also!
all pictures
Here are some soundfiles:
standing
engine start and driving
Regards, Ingo
Beschreibung:
Regenbogenfahne
Material: Polyester
... no response from SW??
Beschreibung:
Regenbogenfahne
Material: Polyester
I have ordered the exhaust system from RES - Motorsport, this is an belgian tuner.
The exhaust is handmade and costs 595 Euro.
If I have it i will post a sound file on the forum.null
Looks very interesting!!
Real Custom!!!
Does RES already have knowledge about smart-exhausts??
Ingo... and HNY
Beschreibung:
Regenbogenfahne
Material: Polyester
They gave a real "profi" impression.
I will let it install on te 15th of january.
I will let you know what the result is.
Ciao pé
This is the auspuff that I will buy.
It costs 595 Euro and is 100% Inox! The warranty period is 5 years!
When I have it I will post a sound file! WOOAAAPPP!
Ciao Pé and my best wishes for 2003!!!!
Cool!!
I´m sure it sounds well with a muffler like this... :-D
Is there still a catalytic converter inside?
Younger Smarts with two Lambdas (Gasoline) will display a malfunction without!
Ingo :)
Beschreibung:
Regenbogenfahne
Material: Polyester
Ingo,
It's a Cdi, it has no lambda.
I will have it installed on wednesday.
Ciao
ehem, on the pictures above you see two lambdas are mounted... so this definetively is not a cdi... I just wanted to know if there is an cat inside or not...probably the second one is not mounted in the exhaust gas-flow and analyses "freh" air to simulate a working cat...
Regards, Ingo
Beschreibung:
Regenbogenfahne
Material: Polyester
Ingo,
The exhaust has no cat!!!
The sound is great and not to load!
I will have the pictures online soon!
Do you know where I can buy the "heckblende" for the Smart. Brabus is too expensive, SW??
You were right, on the photo you cabn see a lambda, so it is a suprex and no diesel.
Mine is a diesel and it has no lambda
Ciao pé
besides the pic's: we wanna LISTEN to the sound !
dann schmart mal schön, Leif
"Und wenn Sie jetzt etwa glauben, mich verstanden zu haben, dann habe ich mich wohl falsch ausgedrückt!" - Alan Greenspan
    • Update: War heute mit meiner Kugel beim unabhängigen Gutachter mit folgendem Ergebnis:   Fahrwerk oder Sicherheitszelle nicht beschädigt oder verformt -> Smart wird sich reparieren lassen.   Problem: Der Gutachter hat einen Riss im Abgaskrümmer des Turbos festgestellt, sprich muss bis zum nächsten TÜV im März 2026 ausgetauscht werden, laut Gutachter nicht durch den Unfall entstanden oder bedingt, eher über Zeit hinweg.    Wiederbeschaffungswert wird wohl + - bei 2000€ liegen, der Restwert bei vielleicht 500€, sprich etwa 1500€ werde ich wohl zur Verfügung haben durch die gegnerische Versicherung. Reparatur mit Neuteilen und Co. bei meiner Werkstatt des Vertrauens wird wohl den Wiederbeschaffungswert erreichen oder sogar übersteigen, ohne Krümmer versteht sich, da ich keine Unfallschuld trage können die Reparaturkosten bis 30% über den Wiederbeschaffungswert hinaus gehen, inkl. dem Krümmer wird das wohl leider nicht reichen.   @Ahnungslos hat mir schon freundlicher weise seine Hilfe angeboten, um die betroffenen Karosserieteile und evtl. die Crashbox zu tauschen (muss laut Gutachter getauscht werden), die Ersatzteile via Ebay kosten in etwa 200€. Das kann und darf ich laut Gutachter auch so handhaben und wird wohl auch auf das Hinauslaufen wegen dem defekten Krümmer.    Meine Frage ist nun wie teuer das Tauschen des Krümmers nun wohl werden wird und ob sich das im Rahmen bis ca. 1000€ bewegen wird oder nicht? Wie gehe ich das am kostengünstigsten (eher am preiswertesten) an?  Der Turbo selbst hat etwa 60 tKm runter und ist nun der zweite im Smart, der erste flog nach 110 tKm raus.  Muss der Turbo auch raus oder kann der noch drin bleiben, hat ja quasi erst "die Hälfte seines Lebens" hinter sich? Zusätzlich verliert meine Kugel irgendwie ÖL, das aber nicht erst seit dem Unfall wohl aber schon längers, seit dem Unfall und seit dem ich letztens wieder Motoröl nachfüllen musste (eigentlich erst wirklich seit dem) sehe ich auf dem Boden vermehrt Öltropfen (?), könnte vielleicht der Deckel beim Füllloch des Motoröls nun undicht sein (Hab nichts an meiner Art und Weise des Befüllens vom Motoröl o. ä. verändert)?   Lohnt sich das alles überhaupt noch bei meinem Smart oder sollte ich nun langsam an einen neuen Smart denken? Wie sollte ich nun weiter am besten vorgehen, tu mir da nun sehr schwer mit einer Entscheidung?   Wie immer herzlichen Dank für eure Hilfe, Ratschläge und Beiträge!
