dongfang
Differences Between Ball Mill and ultrafine Mill
Both Ball mill and ultrafine mill belong to the grinding machine, but there are big differences between them. Now we will explain the characteristics and differences of the two devices to provide some help for you when purchasing the equipment.
1. Different Equipment Structure
The ball mill is composed of the feeding part, discharging part, rotary part, transmission part (reducer, small transmission gear, electric motor, electric control) and so on. B all mill is mostly horizontal. But ultrafine mill is vertical structure, which is composed of host, analyzer, fan, finished cyclone separator, micro-powder cyclone separator and duct composition.
Ball Mill
2. Different Grinding Fineness
The feeding size of ultrafine Mill is generally 15 to 20mm, and the granularity of finished products is usually 0.044 to 0.125mm. ore milling equipment is mainly used for grinding a variety of stone, ores, building materials, chemical materials, such as graphite, talc, kaolinite, limestone and other materials, etc. It's suitable for engineering and projects with high requirements for some material fineness.
ultrafine Mill
Ball mill is widely used in black and non-ferrous metals processing, fertilizer processing, refractory materials processing and manufacturing, and so on. It can grind the material in dry type and wet type. The finished product fineness is up to 425mesh, which is commonly used for material grinding of mineral processing production line.
3. Different Granularity of Finished Products
The ball mill has fast discharging speed, so its finished grain size is relatively coarse. Its grinding granularity is 0.3 to 0.2mm or 0.074mm in 45%~65%. ultrafine Mill belongs to ultra-fine grinding equipment, the grinding fineness reaches 2μm or below. Common grinding machines cannot meet these requirements. ultrafine mill has the features of stable performance, easy to operate, lower energy consumption, wide adjustment range of product granularity, so it's often used to grind non-metallic with medium hardness.
    • Genau das zeigt, dass die Länge nicht das Kriterium ist. Die Roadster Federn im 42 sind höher als die Serienfedern des 42 auch wenn die Feder selbst kürzer ist.  Eine längere Feder kann auch tiefer sein als eine kürzere. Je nachdem wie weit die Feder unter dem Fahrzeuggewicht gestaucht wird.  Die Federn für Brabus/Sportpaket sind eingefedert etwas tiefer als die 0815 Stangenware. Zumindest was Sachs angeht. Zu der Febi Feder kann ich keine Erfahrungswerte liefern aber da sie explizit für Brabus Ausstattungsvariante angeboten wird, sollte sie ebenfalls tiefer sein.
