smartie68
Suche def.Motorleitungssatz/Stecker 6-pol.für Kupplungsaktuator
Gruss an alle Mitglieder.
Ich brauche den 6-pol.Stecker des Kupplungsaktuators an einem Smart42.
Falls jemand auch einen defekten Motorleitungssatz (der Stecker hängt an besagtem Teil) rumliegen hat, bitte melden.
Über eine positive Nachricht wäre ich sehr dankbar.
smartie68
Hallo smartie 68
diesen Stecker gibts als Reparaturkabelbaum bei smart
Viel Glück mit dem Partsmanager bei smart
    • A easy way to realize the paddlesift without activation keys and programming already exists for Smarts with ZEE before BJ 2003. Look at this site! This little box will be connected in the cable connection between the SE Drive and the ECU. The paddleshift of the smart is based on the Voltage level of the horn connection. If you press the up oder down Button of the paddleshift, the voltage level of the horn connection assumes a defined value. The resistors in the paddles form a voltage devider and the voltage Level takes on a value depending on the resistors. The voltage level will be guided via the cicuit of the pcb. And the box will form the switching commands for the ECU. The switching commands to the ECU are based on the Informations of the Pins 3,4,5 and 8 from the SE Drive Unit. Pin 9 is for the sending of the switching mode Manual or Automatic to the ECU.   The Connections between the SE Drive and the ECU will bei listed on that site. And the complete connections of the ECU will be listed here.   I think it will be a problem to get a complete full schematic or circuit diagram of the SE Drive. 🥺
