lukeinnz
    2
Aktivieren
  1. Hey, I saw your post where you used DAS on a Smart 450 and activated the Taktventil / wastegate bypass regulator valve and heard it clicking. I’m trying to reproduce that actuator test using an ELM327 and Car Scanner on a Smart 450 with the MEG_450 ECU. Would you be able to tell me the exact raw KWP2000 command that DAS sends when you activate the Taktventil? Ideally I’m looking for the TX/RX hex from a diagnostic trace, something like: TX: ... 30 XX ... RX: ... 70 XX ... If you don’t have the command directly, could you possibly record a DAS/Vediamo communication trace while running the actuator test once and send me the relevant lines? Alternatively, if you have the MEG_450.CBF file from Xentry/DAS, that would also help because I can extract the actuator command from it. The specific actuator I need is “Wastegate bypass regulator valve” / Taktventil / Ladedruckregelventil. Thanks — I only need the raw command/identifier, not the whole Xentry installation.
